Author Topic: zombies & ghosts on the loose in kingdom 10/18/14  (Read 2774 times)
« on: October 18, 2014, 04:13 PM »
zombies & ghosts from Sleepy Hollow game arrived in the kingdom 10/18/14
click on them or if they catch you first you are sent to sleepy hollow
Seems like the rooms that are dark have these zombies and ghosts so far.
seems there are 100 to capture, you get a popup for each one you click on
prizes will be posted here once i know.
« Last Edit: October 18, 2014, 04:23 PM by funfly »
Re: zombies & ghosts on the loose in kingdom 10/18/14
« Reply #1 on: October 18, 2014, 05:42 PM »
once you "capture" all 100 you get this pop up:
ou helped capture a ghost!
Your exceptional ghost hunting abilities have been rewarded with a Zombie Invasion Pin!  You can find the Zombie Invasion Pin in your inventory now!
Great job!
CHECK SPOILERS IF YOU NEED A COUNT BY ROOM
« Reply #2 on: October 19, 2014, 06:49 AM »
just found out there are more ghosts/zombies roaming than the 100 found prior.
so check lots of rooms more than what I posted in spoilers.  Will add to the spoilers as I can.  unsure of further prize at this time
