Author Topic: space B4 - 4th mission  (Read 2235 times)
« on: August 31, 2014, 04:12 PM »
4th missionfor Space B4  8/31/14
vfk main page:
The radiation leak has spread throughout the sector, and will continue to cover the entire station. Your mission is to seal off the radiation leak before it overloads Space Station B4, and causes a catastrophic explosion.
Remember, you need a White Space Suit and the experience gained from launching 5 Space Merchant Missions before you can board the Space B4 station!
Find out more at DevBlog.EpicAges.com!
and the developer blog:
Space Station B4 has experienced a massive radiation leak, spreading throughout your sector. Your mission is to seal off the radiation leak before it overloads Space Station B4, and causes a catastrophic explosion.
The radiation has eaten away the outer layer of your oxygen tanks, causing a slight oxygen seepage. Your oxygen level will constantly be dropping, unless you find an oxygen source to refill your tanks!
To make this journey, you need both experience and the proper equipment!
First, you will need a functioning White Space Suit!
Second, you will need the experience gained from launching 5 Space Merchant Expeditions!
Third, you will need to have completed the following missions: Space Station B4 - Chapter 1, Space Station B4 - Chapter 2, and Space Station B4 - Chapter 3 in order to participate in Space Station B4 - Chapter 4 - Anguish!
And lastly, once you have on your White Space Suit, in order to embark on your new Space Mission you must exit down this corridor at the Galactic Trading Post!
Good luck, Explorers!
