Author Topic: Space Station B4  (Read 3312 times)
Space Station B4
« on: July 27, 2014, 04:13 PM »
per vfk main page:
A New Dimension - B4!
Coming Sunday, July 27th!
There were several attempts made to locate a space station in sector Alpha.
Each time the space station was near completion it would vanish into what our scientists believed to be an alternate dimension!
Now, Space Station B4 has reappeared and has been detected by our long-range scanners!
It is time to embark on the hazardous task of exploring B4, and discover the mysteries behind its disappearance!
Find out more at DevBlog.EpicAges.com!
Per Developer Blog:
Space - The Final Conundrum!
By VFK Development Team | Sunday July 27, 2014 @ 02:33 pm Central Time
A new dimension!
To make this journey, you need both experience and the proper equipment!
First, you will need a functioning Space Suit!
Second, you will need the experience gained from launching 5 Space Merchant Expeditions!
And lastly, once you have on your Space Suit, in order to embark on your new Space Mission you must exit down this corridor in the Galactic Trading Post!
Good luck, Explorers!
Re: Space Station B4
« Reply #1 on: July 27, 2014, 04:37 PM »
When you enter you get a story line
pic of News showing where to enter in Space Shop for the "B4"
http://www.vmknobs.com/index.php/topic,9984.msg67117.html#msg67117
Note: look for control panels
walk/move with arrow keys: up, down,right left
S key to use "Operational Support Devise  ( OSD ) "
Click and drag the left mouse button to rotate camera
Hit the brown doors with S key to open - might be more but not sure
S key to strike/open:  hit the trunks/containers & lockers - HOWEVER AVOID THE  yellow marked trunks.
Use S Key to open the computers/panels.
Use S key to hit the blue triangles also
« Last Edit: July 29, 2014, 02:08 PM by funfly »
« Reply #2 on: July 27, 2014, 05:58 PM »
you should get a popup saying once you have received the items that you can "clear that area"
once I left and returned to space station thru their portal/door
I got this pop up
Objective Completed!
You have cleared this area of the space station, and have received the items you recovered on your way!
You have received the following items:
- 750 Credits
- 750 Credits
- Elemental Collection Bottle
- Mysterious Space Bottle
- Borinthian Leather
- Baumwolle
- Baumwolle
- Baumwolle
- Bundle of Wood
- Bundle of Wood
Congratulations on clearing the space station area, and retrieving the items!
- 750 Credits
- 750 Credits
- Baumwolle
- Baumwolle
- Baumwolle
- Bundle of Wood
- Bundle of Wood
« Last Edit: July 27, 2014, 06:00 PM by funfly »
« Reply #3 on: July 27, 2014, 07:13 PM »
Once you've completed this, if you try to enter it again you are kicked back to the Space Station Store and get this pop up:
Space Station!
You have already cleared the current Space Station areas!  Watch out for more information on the Space Station status!
Re: Space Station B4 CHapter 2
« Reply #4 on: August 03, 2014, 05:19 PM »
chapter 2 of B4 started 8/3/14
in the News it stated:
must have completed 5 space merchant expeditions prior
must wear/have in inventory white space suit
Keep volume speakers up as there are a lot of reminders from your space suit computers and the stations computers that will be helpful during exploration.
HINT: when you first enter the station, remember if you hold down SHIFT while moving, you'll start running.
TIP: if you happen to misplace your Operational Support Device (OSD) to pick up a substitute device press the S key on your keyboard.
Once completed you are awarded:
- 500 Credits
- 500 Credits
- 1 Sand Dollar
- 1 Sand Dollar
- 1 Sand Dollar
- Baumwolle
- Baumwolle
- Bundle of Wood
- Bundle of Wood
- Space B4 Station Teleporter
« Last Edit: August 03, 2014, 07:46 PM by funfly »
