Online Worlds > smallworlds.com
Did everyone receive tokens?
AmberDaze:
I'm going to look on the SW forums to see if anyone else is having this issue...will let you know if I find anything. :)
AmberDaze:
Apparently I misunderstood the way the tokens worked...eh, it's too bad we all couldn't have received the same amount.
Kаsiks:
--- Quote from: AmberDaze on November 10, 2008, 07:45 AM ---Apparently I misunderstood the way the tokens worked...eh, it's too bad we all couldn't have received the same amount.
--- End quote ---
And how does it work since you seem to have found an answer (I need to say I have not looked for an answer myself since I am really not into SW) ?
AmberDaze:
Apparently, they gave x10 tokens, which means if you had zero tokens x10, you would receive nothing. If you had 10 tokens, you would receive 100...if you had 1000 tokens you would receive 10,000 tokens. If you already had 10,000 tokens, you would receive 100,000 tokens.
Kаsiks:
--- Quote from: AmberDaze on November 10, 2008, 04:51 PM ---Apparently, they gave x10 tokens, which means if you had zero tokens x10, you would receive nothing. If you had 10 tokens, you would receive 100...if you had 1000 tokens you would receive 10,000 tokens. If you already had 10,000 tokens, you would receive 100,000 tokens.
--- End quote ---
oh ok, thanks, I thought there was something else like how many days you played the game that I was not aware of
Navigation
[0] Message Index
[*] Previous page
Go to full version
