Author Topic: Friend's List Question  (Read 32255 times)
« on: May 26, 2008, 11:48 AM »
Is there away to sort the friends list alphabetically?
Kаsiks
  • Liked by the Tag Fairy
Re: Friend's List Question
« Reply #1 on: May 26, 2008, 12:01 PM »
You can by using move to the top button but you need to do it for each friend, dont know if there is any other way
« Reply #2 on: May 26, 2008, 12:03 PM »
Thanks Key!  :bighug:
Kаsiks
« Reply #3 on: May 26, 2008, 12:07 PM »
NP, maybe there is a better solution but that is the only one I see  :-\
AmberDaze
  • I'm not dead either
« Reply #4 on: May 26, 2008, 04:55 PM »
Haven't looked for a better solution, but if you're going to do it this way I would start at "Z" and work your way up to "A." -- trust me on this.  :D
Once a bridge blocker, always a bridge blocker...
Fireworks Highscore:
8552, on 8-2-07
« Reply #5 on: May 26, 2008, 05:04 PM »
Days, I did exactly that.  I took a print screen, typed the titles in to Microsoft Excel and did a reverse sort.  So, I am a bit more organized, for now.    :)
Kаsiks
« Reply #6 on: May 26, 2008, 06:06 PM »
I wanted to see how the select check box and the move to the top button worked together when you select more than one friend and now my friend list is all messed up  :-\ I think I will class my friends by order non alphabetical to change compared to happy  :rofl2:
« Last Edit: May 26, 2008, 06:08 PM by Kasiks »
AmberDaze
« Reply #7 on: May 26, 2008, 07:11 PM »
I've left my friends list alone, only because if I alphabetize it and then get a new friend, where are they going to go?  :groan:
8552, on 8-2-07
fantasymooma
« Reply #8 on: May 26, 2008, 07:17 PM »
Agreed. I tried keeping it neat and pretty, but gave up.
« Reply #9 on: May 26, 2008, 07:19 PM »
I'm sure I'll join that club again before long.
Kаsiks
« Reply #10 on: May 27, 2008, 01:37 AM »
as far as you keep it in order now that it is ordered by alphabetical order it should be easy to do
